Advise/help needed to install Two Bros slip-on
I have an '06 DRZ400S.  I picked up a Two Brother slip-on on Ebay for cheap and it came with the mid-pipe and clamp to tighten to the stock header.
My question is: the stock exhaust had a welded-on "attachment" bracket on the mid-pipe that bolted it to the right passenger foot peg hanger to the sub-frame.
What possible choices do I have to attach the mid-pipe of the new Two Bros. to the sub-frame that does NOT have the same welded-on attachment?
Is there a bracket I can buy or will I have to fabricate something?
Thanks.
The E Model does not have the attachment. You are fine to run without it.
Generally exhausts meant for the S/SM have this extra attachment point.
You can always use a plumbing clamp,  the one that you tightend down,  those are strong enough,   or weld one on,  i would rather have a plumbing clamp on there rather then nothing at all.
actually the E has the attachment as well, its just about 1/2 inch closer to the header.
i dont know why the two brothers pipe does not have that, it is a functional mounting point.
