2012 kx250f oil draining issue
So I'm getting ready to split the cases and do some work on this 2012 kx250f. Trying to figure out this issue I'm having with the oil not fully draining. You can fill it up with oil and it will just sit in the clutch side for the most part. You pull the drain plug and oil will come out but you look at the sight glass and oil is still full in there. So for some reason all the oil isn't draining and something is blocking it from coming out of the clutch side. Any input would be great for what to keep an eye for when looking everything over. I'm just a little confused on what it could be.
Thanks
About 200ml stays in the bike, can't get it all out
I'd love it if it was only 200ml but it's a lot more then that in there. I pull the drain plug and the oil never goes down past the sight glass. You can have the drain plug out and pour oil in and maybe a trickle will come out. If you drain he oil the sight glass should be clear of oil and when you pour oil in it should flow out the drain plug. Something on the right crank case is blocking it for some reason. I'm just looking to see if anyone know what might to look for or where to start. Should be splitting the cases this week
Don't forget to push the kick starter over a few times to pump out the rest the oil
Yup, I did that also. I wish it was that simple
Have you blown clutch fiber plates up ? Wondering if a piece is blocking the lower passage.
Now where is this lower passage? I'm guessing I can blow out all the passages when I split the cases or can I find out if it's blocked befor splitting?
Pull the clutch side outer case and you will see if there's a blockage. If you've ever broke a clutch fiber it's where it could settle and block the oil
I'll look when I get home. I have everything torn apart ready to split the cases
Let us know what you find
Found out why the motor had issues and why it most likely isn't draining. Metal and fiber sitting all by the drain hole and I'm thinking it has some in the ports. Going to clean everything very well and blow everything out with air. Putting a new oil pump in as well from anything that past through that. Better safe then sorry
Wow that's some decent sized pieces of metal!
Yeah it's not great but can be fixed
Of course, that's the main thing!
