premix gas
You want to mix what you'll use and not much more. All petroleum based fuels deteriorate, some more quickly than others. Gasoline is particularly prone to greater detonation when stored in plastic containers like an off road motorcycle gas tank.
As far as separation of oil and fuel goes, if there is any (depends on the type of oil), starting the bike and riding it will re-mix it. But you still should mix and use what you need when you need it.
Worst case is throw some seafoam in there and itll be fine for a month. Or just dump the extra in your car
91 YZ 250
05 RMZ 250
99 PW 50
