Wheel bearings DNA
Ok so I thought the bearings were going bad on my rear aftermarket dna wheel but the bearings arent bad the axle is slightly smaller in diameter. (Which is bullshit)
I bought the 2009 crf450 pivot works rear wheel bearings and seals from rockymountain
Will the pivot works bearings made for a stock 2009 crf450 wheel of the correct inner race diameter fit in my dna wheels?
Just wondering, so I dont get my old bearings out and have the new ones not fit and &%$#@! myself
you'll have to contact DNA to find out what bearings you'd order or if the OEM bearings swap. But the worst case scenario is to simply pull the bearings in the wheel now match them up. Sealed bearings are usually industry standard stuff. Its not like the Honda OEM crank bearings that are intentionally odd sized.
I recently modified a Blackbird swing arm for my 83' CB1100F and found that the ARM bearings are just standard bearings. Honda OEM bearings were 16 bucks a piece, I found 10 bearings for 10 bucks on ebay.
