Replacement time
I have a 2008 yfz450 with the following mods. And the quad has close to maybe a little over 100 hours and has been ridden hard, but has been well maintained. When should i replace the clutch assembly and have the motor rebuilt? I was thinking it should be done soon but it's running fine. Any help would help haha thanks!
Fmf megabomb n q4
Dyno jet kit
Pro armor bully bumper
Houser racing grab bar
Kenda kutter rear tires
Powermadd hand gaurds
Pro armor kill switch
Pro taper handle bars
Odi rogue lock on 130mm grips
Pro taper grip donuts
Light speed carbon fiber sprocket cover
Tm design works chain guide
Turner gas cap
Blue Cv4 radiator hoses
R&D power bowl
Pro armor revolution nerf bars
Pro design intake
K&N air filter
Asv3 brake and clutch assembly
Ride engineering oil plug
Fmf megabomb heat shield
If your rich (unlike me) most do it every season but if I were you I would wait until it absolutely needs to be done but thats just me.
As far as the head/valves go if you have to shim them more than twice I would suggest getting new valves and springs or it could get A LOT more expensive. Far as crank shafts go if you start to see any gold colored shavings in your oil filter replace the crank shaft and bearings immediately. The piston I wouldn't go more than 80 hours depending on how you ride. But these are from my broke ass riding things till I had to fix them lol. But I do use good oil and change it often and also keep a clean air filter in my toys.
