Kick Starter Spindle. Install question.
Xr650R. I was removing my clutch basket and when I pulled the basket off, the kick starter spindle 'popped out".
I followed the directions in the manual and slid it back in and reinstalled the spring.
Now the kick starter doesn't feel right. I goes down when I push it through but doesn't return or align correctly when I pull the kick starter back up.
I taken it apart 3 times and am obviously missing a step.
Any idea?
Right,
1 Check that the dot ons the shaft and thingy align as per the manual.
2 Attach kickstart lever
3 Hook spring in case.
4 Hold the end of the spindle on the bearing but do not insert yet.
5 Twist spindle over 250 degrees, really winding up the spring.
6 Now insert the spindle in the bearing.
7 slowly release the tension
Everything show be tight and good. If not, do it again
BTW, search is you friend :-)
That was it. With the spindle installed, the spring rested just a bit off the insert hole. So I wound the spring over a full turn, then inserted it into the hole.
That fixed it.
