Rekluse question
Installed the exp on my 04 rm 250. My idle was set right before. When I put it in gear it idles real low. Makes me think it's gonna die. I turned the idle half a round out and it creeped and stalled is it normal to idle low once in gear?
Free play is set and I broke it in correctly just doesn't idle has high as before and when in neutral
When the engine is in neutral, the Rekluse should have little or no effect on the idle speed regardless of how it was set up.
It's all normal until I put it in gear. It just idles lower than normal then. It doesn't die. Just didn't know if the lower idle is normal
With the bike in gear, turn the idle up until the clutch is just starting to engage. If the idle is still to low, you need to make an adjustment to the EXP. Check the Rekluse website for instructions.
Idle needs to be up some when you install a recluse as there is SOME clutch drag slowing it down. Just turn the idle up enough to compensate.
Joe
