Which PWK for an 02 Cr250 and who has the best deal?
I want to get a pwk carb for my bike and was wondering which is best for my bike. I would assume the 00 cr250 carb is the one that I should get.
Also, who has the best deal on them?
I live in southeast Tennessee where elevation will probably be 900 +/- 500 feet. Its humid and the weather right now is around 60~85 degrees. Will i need to get any particular jets, needles, etc to establish a good base setting?
If you are a woods rider go with a 36mm pwk, track go 38pwk. Carb Parts warehouse has a good deal and they pre jet it for your elevation, engine mods ect. And they send you extra jets in each direction( leaner/richer). Great people to deal with!!
Could you please elaborate, on why the 36 would be more suited for a woods set up?
The smaller port flows less air but at a greater velocity which increases low end torque.  Frankly, it is over rated IMO.  Just get the 38mm PWK and then if you want more low end, get Low/mid porting from a 2 stroke tuner and have the best of both worlds.  My 06 with a 38mm PWK has all the low end torque you could want and it still revs out in the top end.  A smaller carb will cause a loss in top end.
The smaller carb will increase the velocity of air and fuel charge into crankcase, which will give you much better throttle response at lower rpms. Will be very crisp and clean right off idle..
I decided that im just gonna get the 00 CR PWK carb. I will probably order from Honda East Toledo, unless there is someone that has a better price. Will the jets be good to go as is or are there any special jets, needles, etc that I should also order?
Honda East Toledo has the '00 carb for $180, with free shipping. That's the best deal around right now. The stock '00 jetting is pretty good. Run it that way and tune from there for your specific needs.
