2010 sx-f broke in half &%$#@!?
so I'm contemplating fix it or part it out . I'm not sure what way to go all wires cables and hoses are ripped off and I have broken triple clamps smashed front wheel  crushed and buckeled exh system what bikes would make good parts bike for a 2010sx-f  ?
Wow! If that happened to me there would be a call to KTM whether it's four years old or not! Got any pictures of the carnage so we can try and figure out why there was such a catastrophic failure?
To me, that seems like the steering stem nut was loose and as a consequence, during the ride came too loose and the moment the front got unloaded, the whole assembly came out of the bike, JUST as the front wheel came back down again. That would cause all the damage listed here and makes the most sense.
Initially I thought the bike hit a brick wall (something hard) at a high rate of speed. But I can't imagine that destroying the steering stem MID way through? that doesn't make any sense... the stem would crack at the top or bottom of the triple clamp, not ABOVE/BELOW the bearing, seems strange to me.
Call them and say what? I hit a tree and broke my bike? LOL
  • Like 4
The OP was being elusive in his original post and shared no details. Title made it sound as if his bike just broke in half... just doing some fishing.
My thoughts as well. Looks less like a "frame" failure than an improperly torqued steering stem.
Hold on guys, I bought this 2010 sx-f 450 for a reasonable price and have been cleaning it up and assessing and inspecting damage. So far I can see that if I had an exhaust I could start it up, I have located 2 prongs in the harness that I can link with needle nose pliers and make it crank over.
I pulled the pipe and plastics and cleaned it up a lot to help with finding all obvious damage and so far it seems that I will need
water pump cover
stator cover
triple clamps and stem
front and rear wheel
hyd clutch hose
exhaust system
throttle cables
hot start spring , plunger, plastic cable end
steering limiter
front fender
forks seem to work fine independently without sticking or leaking but I'm thinking I will clamp the upper tubes in a vice and rotate the lower part's to determine if I have a bent fork or two.
So I need to figure out what years parts inter change on the motor (2010sxf450) and I'm guessing wheels 03 to present would fit?
By the way the bike drifted into a tree at popkum moto park and if any one has any of the parts I mentioned that they might be interested in selling shoot me a pm with a contact number
Byron I think you are in texas and I,m on the west coast shipping could be astronomical to 98166 but send me a price shipped to lylecraft500@live.com and if you have other things I mentioned, I'm interested.
looking head on in the first picture the right frame rail of the engine cradle it looks bent, it appears the lower part is moved left when looking at the bike ?
 if any one has one of these bikes could you have a look and see if yours appears to look the same? looking at frames in the past I cant help but notice they all have many bends in them making it hard to figure it out with out looking at an other one from the same era- model. And if I get some good help I might tell you guys some more about the crash lol don't miss your chance.
Looks bent.
I have a few on those here
Edited by jar944
well crap I was just getting ready to go over to ktmtalk or fleabay - I pm'd you my number jar944,
Decent carnage, I was expecting to see the head tube snapped off, I wonder what sheared the spokes/hub? Maybe the stem? Original owner must have had a nice ride when that happened
the original owner was fine after getting ejected when smacking that tree taped in 3rd gear, he would make a gorilla look like a runt
yeah looks like some serious tree smackery.  There was a brand new 2012 motor on the local cross country board for $1700.  you are probably too deep but that would get you a 5 speed tranny and the new conical spring clutch:)
