99-02 kx250 rear shock
will a rear shock from a 99-02 kx125 work on a 99-02 kx250??????
thanks
Though those years are similar, all the shocks may not be the same length.  You may want to check on that.
I think in the same year for those four years, the shock is the same for KX125 and KX250, just a different spring rate.  Hopefully, someone can chime in with more info.
Should be a direct swap.  I think the 250 uses a different swingarm but the linkage pull rods account for that.  For best results you would want to use the 250 spring.  The valving is probably not significantly different.
