RMZ 450 Hot Set up database
All the other forums have a set up data base sticky. Seeing as we don't get as much traffic through the RMZ forum it is a little harder to find set up info. I will fill out the form first so that you get an idea of what goes under each category in case you are not 100% sure what goes where.
Any ways... lets try to keep the format exactly the same for everyone (which I will list below) so that it remains as easy as possible to follow. Feel free to ask any questions along the way but if you post your set up be sure keep it easy to follow.
Copy and paste this to your post and just fill in your information.
Year of RMZ:
Rider weight/ height:
Type of riding/ class or skill level:
Where in the RPM range you spend the most time:
Engine mods:
Exhaust:
Fluids, Oil/ fuel/ coolant
Intake:
Suspension mods: (feel free to post clicker settings, valving if you have it)
Body mods:
Bars:
Controls:
Gearing:
Tires:
Wheels/ hubs:
Satisfaction level with the bike:
Add pic of your bike if you wish here:
Edited by BDubb106
  • Like 4
Year of RMZ: 2012
Rider weight/ height: 225/ 6'4
Type of riding/ class or skill level: mid pack B class
Where in the RPM range you spend the most time: mid/top
Engine mods: Head ported, Ti valves, cams, 13.5:1 CP piston, ISF trans., Moose Rad cap
Exhaust: Yosh RS-4 Ti system
Fluids, Oil/fuel/coolant: Rotella T triple, 50/50 Cam2 93 pump/ Engine Ice
Intake: Air4orce, No Toil
Suspension mods: FCR springs and revalve (with "works" pistons) will complete later
Body mods: Tokyo mods engine mounts, misc anodized parts, CV4 Hoses, works connection rad braces, Acerbis skid plate
Bars/ grips: Renthal Twinwall 998/ renthal kevlar, Acerbis hand guards
Controls: ASV pro pack, Braking rotors and Renthal RC-1- pads, hammerhead foot levers, Pro series Flo pegs
Gearing/brand: Stock/ Talon sprockets
Tires: Bridgestone M304/404
Wheels/ hubsExcel A60/ stock but looking
Satisfaction level with the bike: 100% Love this bike. Turns on a dime with a very predictable motor
Add pic of your bike if you wish here: Pic will be posted soon
Edited by BDubb106
Year of RMZ: 2013
Rider weight/ height: 205/6'2"
Type of riding/ class or skill level: B
Where in the RPM range you spend the most time: Midrange
Engine mods: None
Exhaust: Stock
Fluids, Oil/ fuel/ coolant:  Rotella
Intake: KN FILTER
Suspension mods: RG3 revalve. stock piston and springs,,snugged up steering stem nut
Body mods: None
Bars: Stock
Controls: Modified throttle tube for quick turn
Gearing:  Stock
Tires: Bridgestone M403/M404
Wheels/ hubs: Stock
Satisfaction level with the bike: Very happy
Edited by Cur4Sanity
Year of RMZ:2011
Rider weight/ height:180/5'9
Type of riding/ class or skill level:Class B
Where in the RPM range you spend the most time:upper mid
Engine mods:Stock
Exhaust:Stock
Fluids, Oil/ fuel/ coolant: Lucas Oil 20w50,93 pump gas,
Intake:Stock
Suspension mods: teflon ring rear shock. fork stock:13 comp 9 rebound.2mm up
shock:12 comp 8 rebound 105 sag
Still not 100% on the setup..
Body mods:Stock
Bars:Stock with scott pyramid grips
Controls:Stock
Gearing: 13/51 talon with did x-ring chain
Tires:bridgestone m203/dunlop mx 51
Wheels/ hubs:stock
Satisfaction level with the bike: 80%
Add pic of your bike if you wish here:coming soon..
Year of RMZ: '12
Rider weight/ height: 220 6'3
Type of riding/ class or skill level: open b vet/sporstman
Where in the RPM range you spend the most time: low-mid
Engine mods: stock, do not use the couplers
Exhaust: akro ti
Fluids, Oil/ fuel/ coolant  rotella, premium pump, engine ice
Intake: moto tassinari w/short stack, twin air power flow cage and filter
Suspension mods: 49mm a kit, 12 mm comp, 9 rebound, 5 mm up.  a kit shock rcs ti spring 12 comp 12 rebound, 105 sag
Body mods:  full monty ti kit w/axles, xtrig clamps, cv4 hoses/cap, re front brake, oversize disk, hammerhead shifter and brake, hinson clutch cover, carbon f protectors, works connection holeshot device, think seat, stompgrip cover, etched ignition cover, etched and pc valve cover, pc tank, front flo plate
Bars: tag t2 windham bend
Controls: arc mnemlon levers (zook ratio), raptor ti pegs, renthal kevlar half waffles
Gearing: 13/52 (+1 rear)
Tires: pirelli mxms32
Wheels/ hubs: did lt-x, tcr hubs
Satisfaction level with the bike: 9 outta 10, only because nothing is perfect
Add pic of your bike if you wish here:  upload it later
Year of RMZ: 1 2013 1 2014
Rider weight/ height: 200lbs. 6'
Type of riding/ class or skill level: Vet
Where in the RPM range you spend the most time: Low to high-mid
Engine mods: Stock..White (aggressive) coupler
Exhaust: Yosh (13) FMF (14)
Fluids, Oil/ fuel/ coolant: Rotella Shell 93 1.4 Rad. cap. (Autozone)
Intake: Stock
Suspension mods: 102 sag..Forks flush..Steering nut tightened firmly..Rothaholic's Remove 3 shims in damping side of fork.
Body mods: Acerbis skid plate..Devol Rad. Guards
Bars: Twinwalls CR high
Controls: Works Connection perch holders and Hot start. Works Connection H/Shot device. Roll-on quick throttle
Gearing: !3 X 52 116 Regina o-ring
Tires: Dunlop MX 71's (13) MX 52's (14)
Wheels/ hubs: Stock Two extra rear wheels with MX 31 and MX 51. Extra front with MX 71 Driven oversize rotors on front wheels.
Satisfaction level with the bike: Confidence builder...if you can't make this bike work you ain't trying.
Edited by gordybaird801
  • Like 3
I guess there are just these few RMZ 450's out there. I would like to see other riders set-ups. As well as keep this BDubb 106 thread @ the top. Rothaholic, Mike rides, others.....calling you out.
  • Like 2
I figured it would be easy to get guys to post their set up's in this thread. The Yz 2 stroke thread has 1000's of set up's posted in it.
Year of RMZ: 2012
Rider weight/ height: 215/ 6'
Type of riding/ class or skill level: B HS / C MX
Where in the RPM range you spend the most time: Low/mid
Engine mods: cleaned up ports. Matched them to intake and exhaust. Hinson basket and cover. Full kg clutch. Awaiting cheap manual rekluse core set up!
Exhaust: Fmf ti4 full
Fluids, Oil/ fuel/ coolant: redline 10-40 syn or rotella 5-40 synthetic. Engine ice.
Intake: Twin air filter
Suspension . EVO ind. DLC on shock and forks. Outers coated darker. springs: 49 front 1.6 ics, 5.7 rear spring , snugged up steering stem nut
Body mods: None
Bars: Currently twin walls with cut crossbar 999
Controls: arc levers, pro taper throttle tube
Gearing: 50 rear or 49. Depends where I'm riding. Moose oring chain. Tm chain sliders.
Wheels/ hubs: Black excell a60 rims. Stock hubs.
  • Like 2
Year of RMZ: 2013
Rider weight/ height: 6'3 220lbs
Type of riding/ class or skill level: MX C class
Where in the RPM range you spend the most time: Low-mid
Engine mods: Stock
Exhaust: Yoshi RS-4 Carbon Fiber Titanium
Fluids, Oil/ fuel/ coolant: Suzuki Motor Oil/ 93 Ethanol Free/ Engine Ice
Intake: Screenless intake from the RM250 (Noticeable difference in power!)
Suspension mods: RG3 Revalve, RG3 Triple Clamps, Tightened Steering nut, Ride Engineering rear link (Also an amazing upgrade!)
Body mods: Boyesen Water pump, Boyesen Clutch Cover, Mishimoto Oversized Radiators, Mishimoto blue hoses, Acerbis Skid plate, Oversized Braking Rotor
Bars: Renthal Windham Bend
Controls: Arc Breakaway Levers, Quarter Turn Throttle Tube
Gearing: Stock Front and 51 rear
Tires: Dunlop MX31 front and rear
Wheels/ hubsExcel A60 Wheels and Talon Carbon Fiber hubs
Satisfaction level with the bike: I couldn't be happier with my bike!  I have my suspension dialed and would argue that my SFF forks are better than yours!  :p  I also highly recommend the Ride Engineering rear link.  My bike felt great before and even better now!
  • Like 3
Year of RMZ: 2014
Rider weight/ height: 5'9 165
Type of riding/ class or skill level: Desert
Where in the RPM range you spend the most time: mid to top
Engine mods: yoshimura pim 2
Exhaust: yoshimura titanium/carbon rs4
Fluids, Oil/ fuel/ coolant engine ice motul 300v
Intake: stock intake notoil superflow filter
Suspension mods:  forks flush preload all in clockwise bebound 12 clicks compression 15 clicks out.
Body mods: Yoshi graphic and engine plugs
Bars: stock
Controls: stock
Gearing: stock
Tires: bridgestone m404
Wheels/ hubs: stock
Satisfaction level with the bike: once you get the suspension dialed in and open the motor up to breath more. this bike is amazing. im really happy that I went with Suzuki. this bike gives me confidents to do stuff that i would question on my older 2smoker. i love the power of this motor. very forgiving when you get tired but still puts a big smile on my face when you roll out of a corner in 3rd gear.
  • Like 2
Year of RMZ: 2012
Rider weight/ height: 6'1" 183lb
Type of riding/ classicon1.png or skill level: MX  Vet/ B
Where in the RPM range you spend the most time: Upper Mid
Engine mods: Rekluse Core EXP, rerouted breather and wiring, GPI oversized Rads
Exhaust: FMF RCT 4.1 Titanium w Rich Coupler
Fluids, Oil/ fuel/ coolant 93, Rotella, Engine Ice
Intake: Uni/ ProSeal with No Toil oil RM Cage
Suspension mods: Forks: CCycle valving .49 Springs, Shock: CCycle valving w Smart Performance modified Showa piston and Eibach 5.7 spring
Body mods:Stock
Bars:Stock Renthal
Controls:Stock
Gearing: 13 51/52
Tires: Pirelli MT32
Wheels/ hubs: Stock hubs/  DID STX
Satisfaction level with the bike: Best bike I have ridden...confidence inspiring
Add pic of your bike if you wish here: Coming Soon
Edited by mikerides33
  • Like 3
Year of RMZ: 2013
Engine mods: Stock
Hey bud.....do you have any issues with losing coolant using the Boyesen Water Pump?
Rider weight/ height: 205/ 6'3"
Type of riding/ class or skill level: Motocross/ Vet A
Engine mods: Boyesen water pump, high pressure radiator cap
Exhaust: FMF full Titanium
Fluids, Oil/ fuel/ coolant: Rotella/ 94 octane pump gas/ Honda HP coolant
Intake: Twinair
Suspension mods: (feel free to post clicker settings, valving if you have it): Pro Circuit
Body mods: Guts tall seat, works connections skid plate, radiator braces, red radiator hoses, tm designworks chain guide complete system
Bars: Renthall Fatbar Rc/ stock Honda bend
Controls: Galfer Tsunami over side rotor, Ride Engineering brake caliber, pro taper twister throttle, works connection elite perch, Braking rear brake caliber, Raptor footpegs (awesome), hammerhead shift and brake lever
Gearing: one tooth up on rear sprocket
Tires: Michelin MH3 rear, Bridgestone 403 front (I think)
Wheels/ hubs: stock so far
Satisfaction level with the bike: handles very well. Motor is solid. Suspension is good after modifications. Loses coolant. Bike is easy to ride. Satisfied
I'm concerned that the Boyesen water pump expedites the departure of coolant. Anyone have an issue with this? I'll post a pick up when I can. I've been a honda guy for years (I have a 2006, 2012, and 2013 CRF 450 that I also ride) and wanted to try a Suzuki for a change. It's nice to have a direct comparison with the other bikes.
I just need more time on the bike
How much coolant are you losing? I wouldn't feel right about it, would be in my mind all the time. Also, being an A rider, any direct comparisons to the 13 CRF ( pros/cons)?
Year of RMZ: 2013
Rider weight/ height: 185cm 85kg
Type of riding/ class or skill level: B grade Motocross
Where in the RPM range you spend the most time: All of it
Engine mods: Recluse EXP 2.0, Tusk Clutch kit,
Exhaust: FMF powercore 4 slip-on
Fluids, Oil/ fuel/ coolant: Motul semi synthetic (everyone swears by theirs but all 'good' oil are the same), pump 98, Evian most of the time
Intake: Removed mesh screen from cage
Suspension mods: Revalved shock and forks - no idea what valving but took a heap of shims out and now run a .98 spring, preload all the way out, oil at 310cc both legs.
Body mods: Zeta aluminium bar clamp rubber replacements (never twisted bar mounts into rubbers since), tusk chain case saver, TM designs chail slider & guide
Bars: ODI grips (lock on)
Controls: stocko
Gearing: stocko
Tires: Pirelli and michelin mostly, (i hate putting on dunlop tyres)
Wheels/ hubs: Stocko
Satisfaction level with the bike: Good bike but it takes a lot of work to get the suspension the the level a YZF is at standard. after a year i think i finally like the suspension and it doesnt kick me off, handling and reliability wise this is 10 out of 10.
Year of RMZ:
Engine mods:
Exhaust:
Intake:
Body mods:
Bars:
Controls:
Gearing:
Tires:
Wheels/ hubs:
What's good Bdubb? Well I'm pretty sure you know the year of my rmz....I put the fmf r what ever the titanium slipon on Rekluse and agent up to a 51 tooth in the rear sprocket....I replaced stock sprockets and the noisy stock chain I figured I'd personalize my bike a little with black sprockets and gold chain... The results are quite substantial the engine is completely different as it now runs smooth but angry and does not nose over at high rpms it revs something else now.
Year of RMZ: 2012
Body mods:Stock
Bars:Stock Renthal
Controls:Stock
Gearing: 13 51/52
Tires: Pirelli MT32
  • Like 2
