2013 KLX 140 Suspension Upgrade
Just bought a 2013 KLX 140.  Wanting to up grade the suspension. Seen that kx 85 100 will work.  What years will work and what all will i need.
As long as its a monoshock model it should work. But ill have to warn you bro, its definatly not plug and play. It takes a lot of custom fitting and sometimes even a bit of grinding. I can't tell you exactly how it will for on that bike but the 2008 (my model) I put them were a pain I'm the ass. And the results were less than satisfying. I acctually ended up taking them off and resaleing them as klx 140 shocks.
Very easy to do. I bought the 2002 KX 85 front fork and caliper plus the triple clamp.You do have to add a washer to the stearing shaft just below the large nut. And in my opinion a must is flip the rear link. Which you do have to grind a bit off but also very easy to do.
