Bunch of upgrades for my 06' CRF450R
Hey guys I'm new here. I bought a used 06' CRF450R. It's just had a top/bottom end overhaul right before I got it. The rest of the bike needed some help though. I bought new Michelin AC10 DOT legal tires, Baja Designs dual sport light kit, Trail Tech stator/flywheel and speedo/tach, Boyesen waterpump, Renthal o-ring chain, Enduro Engineering Evolution debris deflectors, lubricants, filters, tools, etc.
Things left on the list are a larger fuel tank, ICW radiators and oil cooler setup, brake upgrades, steering stabalizer, etc. I was more worried about getting it street legal first. I'm not going to be riding it all over on the roads, but just farting around the Troy/Birmingham, MI area. I'm also going to be taking it up to northern Michigan, and in the Algoquin park area in Ontario, Canda for trail riding.
Here are some pictures of it right now. I'm getting it ready for all the parts to arrive next week.
My brain has a hard time imagining a crf450 anywhere its not shredding berms. None the less nice bike keep it comin.
I was kind of weary about it at first, but I found a lot of people who turned them into moto's and figured it should work well enough for my intentions.
Edited by EndGame
sweet looking bike, im in ontario
Thanks! My wife is from Waterdown, ON and we go up to her grandparents cottage outside Kearney, ON.
Edited by EndGame
I got a bit excited and ended up here, haha. I'm replacing all the bearings in it now too, ordered a Jagg oil cooler as well to get some more oil in her, and a high pressure radiator cap.
FYI, those wheel bearings are the blind type... So, I had to order a special puller for that. $40 for one on ebay, not to shabby.
Edited by EndGame
if you have ever ridden a 450 with 17" slicks and a 320mm front brake rotor, in canyon roads, on a gokart track, or from your house to your buddies, in parkinglots, schools, anywhere you can find little jumps and gaps, and stairs to ride down.
in the canyons, sport bikes are smoked, the tighter the better its like drifting the smoothest double track you have ever ridden. 1 finger on the front brake will get you on the front wheel instantly
fooling around on the streets is a blast. theres a gas station around the corner with a sloped curb i use as a kicker to launch over a planter and into the adjacent parkinglot lol!!!!
its a blast!
you would undertand.
its a blast!
The Baja Designs dual sport light kit is here! It has a key switch with it so now I don't have to worry about someone just kick-starting it and taking off with it. Also, the new chain, tire changing tools and tire lube came.
I got a bunch more parts yesterday. I installed the stator in the cover, but couldn't bolt it all up because I ripped the new gasket :facepalm: . The gasket was vacuum sealed in the worst packaging they could've stuck it in. Just as I was thinking I was going to damage that gasket trying to get it out... I did. I wasn't really impressed with it's quality once I got it out, and just ended up tossing it in the garbage. Then I went upstairs and ordered a new OEM Honda gasket(should've done that in the first place). I also found a like new IMS 3.2 gallon tank for $150 on Ebay, so I snatched that sucker up. I'm really debating on buying a new wheel set for it too.
Edited by EndGame
More parts again today! The mounts for the mirrors came and I put them on. Mounted the new tire to the rear. I'm waiting on the new tube for the front, but I took the old tire off to have her ready. Installed one of the new Race-Driven brake rotors on the rear wheel too. The Boyesen water pump came and is now installed. That thing looks sharp, and will hopefully help keep her a bit cooler. Last thing I did today was drill the holes for the rear tail light assembly. It was a pretty straight forward install. Lastly, I'm set on getting new wheels in two months. These ones will just have to get me buy for the time being...
Now both Michelin AC10 tires are mounted on the rims and I put the new Race-Driven brake rotors on. Got the new Renthal 14T front sprocket on, and installed the new Tusk high pressure radiator cap. Now I'm all out of parts for today. Should have more tomorrow and Mon./Tues...
Edited by EndGame
If you decide to get a oversized from rotor, the tusk one is really a great buy. I thought my brakes were fine until I put on the oversized rotor. I see the light!
Thanks for the heads up! I read a lot of good reviews about these Race-Driven ones. I'll have to see how they perform. They also came with matching pads...
Yeah, it's going to be fully street legal. Only once or twice a year I'll be up in the Muskoka area. I'm hoping to hit up the "park to park" trail that runs from the Algonquin Provincial Park to Parry Sound. Otherwise I'll be messing around the Kearney area. My in-laws live in Waterdown, but I don't think I'd be riding it around there much...
Edited by EndGame
