Suzuki LTZ 400 not sure what is happening
I just picked up a 2005 LTZ 400. I tried to turn it over and it just made the clicking sound, almost like it had a dead battery. I put a different battery in it that I know was good and it did the same thing. I'm not really sure whats going on.
Try jumpering around the starter solonoid with a heavy wire.  If that works then replace the solonoid.  if not, take the starter off of the engine and see if it spins over.  If it does, something is jammed up in the gears behind the engine case (as long as the engine isn't siezed).  If the starter doesn't work like it is supposed to then it probably needs rebuilt with a new set of brushes.
