Start up tips. 5 Kick and go.
1 Kick easy three times to charge.
2 Find compresion stroke by slowly slow slow pushing with right foot. You kinda feel a click and it will be hard to push any farther.
3 when u find that spot. Let the kick up to the top. This time when u kick it. It should start. No throttle. Choke only when cold outside. Its. 55 degrees where I am and I use no choke.
Use same steps when engine is warm. First three kicks charge to run efi and fuel pump. Kick four isn't a kick, its just finding sweet spot. Number five is the bees nees.
The fourth kick. May take two. Or three if u pass the sweet spot. But if u fid that spot. Youll be concerned with how to stop the monster you've unleashed. Good luck guys. Let me know if it helps. Or if u have questions.
