Exhaust Differences 05 to 08
In either 07 or 08 Honda moved the engine 5mm. You can make the headers work, but it's not a true fit. I want to say it was 08. 05-07 should be a direct fit. 03-04 are different, its been awhile since i have had those years. so do a little more digging
Edited by iMOTO189
Had an 05 / 06 & the 05 model is considered the 4th gen alum frame going to a different frame & subframe.  In 06 Honda moved the motor 5mm forward to better centralize the weight distribution & also redesigned the subframe.  The 06-08 exhausts interchange & the 05 mounting is different on the mid pipe.  I've read about members fabricating the mounting brackets & making it work.
FYI -
02-04 interchange
05 has its own design
06-08 interchange
