Cr85 forks
Depends on their condition but even if they're in great shape they will still need some work before they can be used on your 150f. Springs minimum because the difference in bike weight alone is close to 60lbs. Then there's the cost of getting everything needed to fit them to your bike. They do not simply swap over. Modded triple clamps alone will cost close to $500. Then there's the brake caliper adapter, steering stop adapter, wheel adapter, etc. be sure you know what you're getting into.
Triple clamps off of E Bay and then shipped to and from Reager for mods are way less than $500.00 probably less than 200?
Maybe 500.00 if every thing was brand new? I will give you that.
Just purchase every thing for a 150r big wheel on E-Bay then you won't need the bearing center spacer for the 150f wheel either.
Trees, axle, spacers, fender, lower fork protectors, nuts and bolts, etc. etc. get it all from a 150r big wheel
Depending on you weight? You may not need heaver springs?
Big wheel springs are heavier than all others... 80, 85's and small wheel 150r's
Edited by adnohguy
