Trailtech Striker Install
Ok, so I finally bit off and bought the Trailtech Striker along with the cluster (neutral, high beam, etc.) and the thumb switch, I got tired of adding a clock, temperature display, etc.  I already had the Trailtech TTO temperature sensor installed so I'll be using that sensor for head/oil temp.  I would really like to NOT hack into the wiring harness!  Even if I have to do the research and source the proper connector from Mouser Electronics, etc.
I've done some searching but no DETAILED installation resources come up.  Has ANYONE here installed one of these and if you have, some guidance would be GREATLY appreciated!
