Klx400 fitting tusk break light switch
Bought a tusk enduro kit for my 2003. The rear break switch is too tall and hits the master cylinder. Directions state that if this happens just put in on the caliper end. How ever that end has even less room. Has anyone had this problem on theirs? Looks like i need to get creative
Clearance between a brake light switch has always been an issue with the remote mounted fluid container.  Options are to move the fluid container or fit the switch to the front master cylinder. Or fit a mechanical switch to the rear.  Rear mechanical switch requires some improvisation to make a bracket and fit a pull spring to the pedal.
