Extended shift lever
not sure, but the only longer levers I have seen available are from hammerhead.
hdmoto.com
I ended up ordering this fr hammerhead.
Here's the factory lever.
D61F3398-8976-4342-8958-D02361BF1A4A_zps
Here's the part I ordered.
64736FED-EBEA-4FA0-A487-4C1F7FF7CF4D_zps
It's actually designed for their levers but I'm going to modify my factory lever to fit. The tip I ordered is +20mm.
Hey Roryrob and others!
I encountered the same issue when I bought my 2012.  The solution was as easy as an aftermarket shifter for an XL650L, it give you a quick and easy 7/8" extension.  The MSR part listed has held up well and still on the bike today.
Here is a link to a post I made on this site a while ago for the very purpose (contains pics and part number)-
http://www.thumpertalk.com/topic/1047784-thanks-for-the-klx250sxr650-shifter-tip-new-member/
God Bless,
TC
Edited by TimC63
Awesome. Thanks for the info. Do you think the shift levers are the same for the older klx300/250's? Yours is a 2012. That's the next generation right?
If I understand your question... yes the 2009+ are the same and are revised/different from the 07 and earlier.  I never did check to see if the Kawi part#s were different between the 2007 and the 2009.
While I do not recall the exact difference, I remember that others had posted that the KLX300R shifter was NOT a solution as the bend of the lever was different and incompatible.(with the 2009+)
TC
