KTM 530 2009 won't start
Hi all I can't find a answer to this problem.
I was out riding with some friends last week. We came to a stop to have a chat. I turned my bike off, then as I went to start it again it wouldn't start. I ended up having to take it home on the back of my ute. I have checked everything and every seems good has anyone else had this problem? It was running fine till I turned it off. It will fire every now and again but won't go
I had an '09 530 but I think the problem I had relates to all KTM's. I had a corroded starter switch on the handle bar which was causing intermittent problems with misfiring & refusing to start. The power button supplies power to the coil & also the starter so while the starter cranks over the coil isn't energized & won't fire. Pull the switch apart & check that. It's a $80 part but the problem cost me close to $1000 before I found this.
2013 KTM 500-EXC & 2014 Triumph Tiger Explorer 1200
