2007 xmoto xb 31 help with clutch wont work what tools do i need?
xb31 250cc cltuch appears to be smoked i have no clue how to change the clutch beacause i think i need a spacial socket of tool to remover this thing off the crank has anyone changed the clutch on theses before>??? i dont even know where to get the tool to remove this thing
cmgyz450fs77,
Check other bike manufacturers for a clutch spring compressor You will need one.. and an impact driver to remove the case screws/nuts.  It would be smartest to take engine to a shop and have them split the cases if that is needed.  In the OLD days, we had a welder make us a spring compressor.  Sorry I can not be much help, because I never worked on that brand of bike before.  Also buy some "Yamaha BOND, we call it yamabond, for the replacing of the side case, they never leak with that stuff.
Good luck
Gary
