43mm conventional swap for IT 200
hey that's my fork swap your talking about.   it was a very good upgrade for the it200. I have 2 of those front ends for sale also if your interested. the98-99 street model and the 97-99 dirt model had those forks.
That what I was looking for-thanks brown.
Which triples did you use?
Are the fork lengths different?
May be interested in setups, should I PM for specifics?
the forks are 43mm just like the it200. the swap is a piece of cake, the dr forks slide right into the it200 triples. its as easy of a swap as there is. I used my forks, wheel, and complete brake setup on the it. about an hour start to finish.  I think they are longer. not sure though. I can check if you want. you could always slide the forks up in the triples a little farther to shorten it up. I had mine as high as it would go and did not mind it one bit. I am actually putting the stock forks back on the it200 and selling it very soon.  feel free to pm me
