Do My Carrier Bearing Need Replaced or could it be something else?
The entire axle is moving front to back. The left wheel is the side that tends to move up the most. I definitely cannot ride it as is and have been told my Carrier Bearing is shot. Is this the only problem or could it be something else? Also, if I sit on the quad the entire ATV will lean to which ever side I put my weight on. However, the left side is worse just as it shows the most play. I might add it moves 3-4 inches towards the front. Just incase I'm not clear, I can literally pick the left wheel up and move it 3 inches, and then the right side goes back 3 inches. Please help and let me know if its something other than the Carrier Bearings.
Thanks
