rmz gear changing mechanism
hello everyone ! i bought myself a 05 rmz250 motor that was in parts and im putting it back togeather, i need help with a spring that helps everthing work when changing gears. it is called a position spring, there will be a link so you know what spring im talking about the part number for this spring is 92145A on the bike bandit website. all i need to know is hoe this spring sits to make sure i have it right. one part of the spring keeps pressure on a lever and the other part of the spring sits somewhere against the case. thank you for any help
http://www.bikebandit.com/houseofmotorcycles/2006-kawasaki-kx250f-kx250t/o/m149121#sch437552
you have it right.
one tang pushes the arm towards the shift drum and the other tang presses on the case it will only work one way.
all though i have heard its advised to use the rmz 50 spring in the 250
