Stripped radiator shroud bolt 05 wr250f
So i have a bit of a problem, I have a stripped bolt on my radiator shroud and I can't remove the shroud and I was wondering if removing the shrouds was necessary to remove the tank.
You have to take the shroud loose from the tank or loose from the radiator louver. As long as you can remove the bolt from the radiator louver you can get the tank off. To answer your question you do not have to take the shroud off the tank to get the tank off. Which bolt did you strip?
Edited by barryh
You can definitely still get the tank off the bike. You should be able to get on the stripped bolt with a small pair of vise grips and get it out.
