Oregon Custom Swingarm Modifications in Portland Area
I need some custom swing arm modification, does any one reccomend a good fabricator?  I don't think the mod is a difficult one however the welds need to be good so the swing arm doesn't break in half after wards :)
I can't respond to the actual question, but I'm wondering: what mod are you making? The reason I ask is because I've got a vintage dual sport that I'd like to get more travel out of the rear, so I was thinking of moving the shock mount positions (top and bottom) a couple of inches farther forward, so the stock shocks and springs would provide more travel and lower spring rate. I'm also changing the forks to a set from a true enduro, which will increase the height of the front to match.
I'm just spitballing here, in case you had a similar idea.
