Pro honda coolant
It's the first winter in quite some time that I didn't drain the coolant. What's the freezing point for pro honda hp coolant? I hope everything's alright.
Why would you leave your bike out in the cold?
I use it , and have not had a problem with my bike. And i keep my 450 in the garage too. We all have a very cool winter this year. Start it up , and look for any leaking. You should be good.
Assuming you poured it straight out of the bottle without adding any additional water, at a 50/50 mix, ethylene glycol coolant/antifreeze will not freeze until -34F. And even at that temperature it will only get slushy, it won't freeze solid until well below that.
If your garage was -34F or lower then you might have something to worry about. Otherwise, you're fine.
Edited by Chokey
