2003 Cr125 won't idle
So my cr125 started leaking gas out of the bowl drain hose when ever it was tilted alittle, I ignored the problem for weeks and so today I decided to take the carb apart and clean it, before I took everything apart it idles strong and never died, I took it apart and clean everything out and put it back together, only a little gas leaks out now but it won't idle at all!! I don't know what happen, I just cleaned it and put it back together. It revs strong but just does want to idle. And if it does idle it's a real low idle but bogs and dies after 5 seconds, any help would be great, thanks!
You probably just need to readjust the A/F mixture screw and then reset your idle screw....but if it is still leaking a drop of fuel then you need to first set that float height to spec and check the float needle and seat are in good order.
