2001 cr250 jetting help
Hi guys I have a sick 2001 cr250 that I love and just got broken in and it is at 1.3 hours so this is my first two stroke and I have a couple questions on jetting and carb settings
*My bike smokes quite a bit when warning up does that mean rich jetting?
*I find it hard to set the idle so that I can use the choke for a cold start and let it idle for a bit but when I take the choke off it should idle very low and die in seconds without small blips of the throttle I just don't see how people do it it starts great first kick and let it run with the choke and during warm up the idle starts to raise so I take the choke of and the idle falls and dies I the try and start it with the choke of and it might hicup a bit but it just seems like the idle is just way way low
My jetting is at 420, 32.5 and 3rd clip
S7 NOZZLE
Mix is 32:1
Temperature is around 75
Sea level 611 feet above
Thanks guys just needin a bit of two stroke help
Thanks Ben
Edited by Benfro89
