CR500AF PWK jetting
I have a CR500AF that I recently did a carburetor swap on. It has a 38mm Keihin PWK A/S or airstriker. I have jetted it and it seems to keep the same needle position and pilot, but just a different main jet. I was looking for something that I could tune in better, because the idle and choke on my PJ was the same and it didnt want to idle without being super lean. I got my PWK to idle with the idle screw turned in all the way, but it seems to sputter as I rev the bike at a stop, even when its warm. I tried to lean out the idle a little bit but its almost like the air/fuel mixture screw does nothing. I mean I literally had it vibrate completely out one time when I adjusted it at the shop, and it didnt seem to do anything different. All the way in and all the way out seems to do no difference. Do I need to get it taper bored because its too small, or is one of the jets just too rich cause of so much vacume pulling more gas through it?
 I want to keep as much part throttle throttle response without it having inconsistent "hits", and that being the main reason I changed. Because people say that it has better part throttle response, which it did, but not much.
I'm not a carb expert in any way but I belive with a pilot too rich the air screw will have little to no effect when adjusted. Pilot too lean and the screw will be very sensitive to adjustment.
Hope this is good Intel.
