lower clutch actuator lever
I have purchased what is supposed to be a 1997 rm 125, my problem is the clutch actuator on the case there was a piece of sheet aluminum holding the end of the cable it was defiantly not factory the cable was trashed due to the angle on it the arm the cable is attached to comes in contact with the case as well I need to know if the actuator is supposed to be bent up or if there is a bracket to make this operate properly. Any help is greatly appreciated and pics are welcome
