2013 kx250 gold valves
So I'm about to install Race Tech gold valves and new front spring in my 2013 kx250f. Just wondering if anyone has done this or stripped any of these before and has some advice?
also how do you bleed the nitrogen out of the rear shock?
I have a service manual on the way so that should be a lot of help, but for now any advice or tips would be great thanks.
Cheers, Dan
I'm not sure on those valves, but there should be a shrader valve under the nitrogen reservoir that you simply push to release the nitrogen. Keep us updated on how you like the valves.
no shrader valve on 13's. It's a special needle and if you jam a sharp object in their to bleed it off you'll damage the bladder cap
