New Member crf50 Question
I have a 2004 CRF 50 F 100% bone stock from factory
Only mod is the spring and rim locks
My question is on my carb for my 2004 CRF50F the manufacturer recommends 1-1/2 turns out on the air screw......
For the last three years I've been running like An 1/8 Turn out on the air screw
everything is been running fine no smoke starts on first kick starts with no choke on in the winter.
I never have to kick hard I can push down with my hand slowly it starts right up...
Should I just go by the motto "if it ain't broke don't fix it"
or should I try the 1-1/2 out????
I'm also 6'2" 275 pounds pulls me just fine no hesitation no bogging. Nothing it runs 100%
Please let me know what you suggest...
Edited by ChrisLow
It's an adjustable 'fuel' screw, not air screw.
You use it to adjust your pilot jet circuit
it is for idle only
Turn it for maximum idle and you are done
False on this one I have (2) I have a "Throttle Stop Screw" Which Is My Idle
And A "Air Screw" Which Is Air/Fuel
Air fuel screw is a flathead
Idle is a Phillips
Edited by ChrisLow
Two strokes have air screws
Four strokes have fuel screw or an air screw
Yours does have an air screw (?)
Both have idle screws.
I mean I guess it could be called something different but the shop service manual is calling it an air screw. It's a 10 year old bike and manual Maybe they have changed the carb since then and call it something different now
