stripped triple clamp bolt
Looking for some ideas, one of my lower triple clamp bolts is stripped..rather the aluminum clamp threads are stripped, you think its ok to ride w/top clamp and 1 lower clamp bolt torqued to spec?
if not, what can I do, smaller diameter bolt that goes all the way thru and then bolt on?
Longer bolt same diameter and hope it catches?
please give me some thoughts...thx
in the past i have swapped us threads for metric and visa vesa going to whichever one is the next biggest one. I only do this in a pinch thou. Im sure you could ream it out and re-tap it to us threads fairly easy
