split case on 04 80
Me and buddy split case to replace cracked left side. Got back together and in bike not getting any oil to top end, no oil coming out of check bolt by plug. Have 1 quart of 10w40 amsoil
Tore clutch cover off to verify all is functional and orings stayed in place behind oil pump. One moved on install first time I reset and made sure stayed in place this time still no oil to head. Started questioning if put base gasket on correctly bought OEM and right now have brown facing top and green facing crankcase. Please help im at wits and boy is driving me bonkers. Dad I wanna ride!!!!
Base gasket will only go on one way to fit over the two dowels on the left side. Did you blow out the oil passage in the cylinder head? Could be clogged.
Bad oil pump previous owner took apart and put back together backwards. Buddy found last night
