Drz Not turning on
Hey guys 2days ago i was riding and the bike suddenly started bogging out and the bike switched off and my speedometer turned off i tried turning it back on wouldn't start ended towing the bike home .. I 1st thought it was the battery ended up changing the battery and I still have the same problem.. Now it's not evan starting ... No spark no nothing! So I rolled the bike down the road clutch started it and turned on but then back to square 1 it bogged out and turned off ... I feel like sumthing is draining the battery or could it be a fuse dono?? What are your thoughts???? Thanx
It's a 2010 drz sm it has 6000 km iam not 1st owner ... What u mean by maintenance.. Do u mean mods in the bike ?
After you have checked the clutch/side kick circuits for continuity and the the main fuse is okay,
you should check the main relay behind the headlight. Turn the ign on and press the starter
button - then with your other hand wiggle the relay in its holder. I had this happen last week,
a few dabs of die-electric grease on the contact fixed the problem.
gerry
wiggle the key in the ignition.
check fuses.
check battery cables/grounds.
remove all the electric connections one by one and apply dilectric grease, ky, vasaline, whatever.
got gas in it ?
