Yz125 ticking after rebuild
Hi guys, Having a little drama with a 2002 Yz125 after rebuilding it,
what is happening is a ticking noise that seems to come from the top end, In my Opinion it sounds like the piston is just touching something on every revolution. It has been pulled down a few times now and according to the manual everything seems to be correct,
The bike seems to make full power and starts very easy, I havent done a compression test but im guessing it will be fine due to the easy of starting
any help would be greatly appreciated
Cheers
Craig
Will you post a video? How are your tolerances between cylinder and piston? Did you check for play in the rod and wrist pin? Any marks on the piston?
put the original piston back in and the noise went, so must of been the wrong size piston
thanks for all your help
