Oil leaks
So I got my bike put together finally but of course it's one thing after another and now my bike is leaking oil all over the damn place in these spots ImageUploadedByThumper Talk1398374657.517943.jpg now idk why it's leaking there I've never even touched that bolt.. Idk what to do about that one. ImageUploadedByThumper Talk1398374747.581031.jpg and where the oil pump connects there it's leaking bad.. I put new seals in it to and it still leaked so it has me stumped too. Any ideas?
ok, pic #2...same issue on mine. Fix? Pushed in and up on the aluminium pipe while tightening the bolt, which adjusted the angle that the pipe presses on the o-ring. Slightly but it did make a difference. Problem "solved"...I was thinking to buy a new dowel pin as I have replaced the o ring already.  Good luck
Okay thanks, I'll try that this weekend, it had me real confused when I replaced the I ring and dowel and it was still leaking.
