CDI from 250sx07 to250sx02
Maybe interchange up to around 05ish.
I remember 06 getting different stuff, or at least the cdi would not just plug right up to the older stuff.
Look at a parts fiche, you can problem determine all this easily.
If any one want to know....
CDI of SX250 2007
Match
To CDI of sx250 2002
with adapted WIRING HARNESS
The CDI in my son's 1999 250 MXC went out.  The '07 SX CDI is the only one available as a replacement and it works great with the adaptor harness.  On the 1999 ,the '07 CDI ends up mounted in a 180 degree reversed position so the CDI connector and wires face forward behind the front number plate.  They give you a template for drilling new mounting holes to give the correct mounting orientation if you want but I just mounted it reversed and taped the wires good and tight so they wouldn't get caught on stuff as the handlebars are turned.
