High Beams and fuses KLX250sf
I recently bought one of the Kawi supermotos. I've had great luck so far other than the high beams and headlight fuses. All of the lights work perfectly other than the high beams as long as the headlight fuse is good, but the fuse has been blowing repeatedly over the last few weeks. Could the switch for the high beams and the fuse problem be related or is this a coincidence? My first thought was a short, but I have traced the wires and they all look good. Any ideas or input would be great!
Thanks in advance
Remove / isolate the head light switch from the bars and see if still does it. switch could still be shorted. does it blow instantly or takes some time? does the low beam stay lit when highs are on? should be one or the other not both?
It ended up being the positive high beam wire a few inches before the headlight. Easy fix.
