High Beams not working/Headlight fuse blowing
I recently bought one of the Kawi supermotos. I've had great luck so far other than the high beams and headlight fuses. All of the lights workicon1.png perfectly other than the high beams as long as the headlight fuse is good, but the fuse has been blowing repeatedly over the last few weeks. I have checked for frayed and open wires and can't find anything. I have heard the switch could go bad over time or the high beam relay could be a problem. Could the switch for the high beams and the fuse problem be related or is this a coincidence? Could a bad switch or relay cause these blown fuses and high beam problem? Any ideas or input would be great!
Not much to these bikes. Use a multimeter to make quick work of locating the short.
You will be looking for a short in the positive high beam wire. Trace that back.
Edited by HuskyRoger
