02 rm125 won't idle need help
How do I adjust the idle screw it cuts off right away if I don't give it gas there is the pic of my carb
Edited by rv1
I don't see it there. Look for a screw with a spring around it or in it "you will feel and hear the spring when you turn it" it could be behind the fuel like or under the carb burried somewhere. I would pop the carb off and look all around it for that
The choke knob is most likely also the idle speed screw. Turn it CCW. You see, it has serrations in the knob.
Your air screw also looks like it is set very lean, see how much its sticking out of the bore?
Edited by Trailryder42
The knob don't turn . What u gotta use pliers or something? On the knob I think it says idle on the choke but I can't really see it
No, don't use pliers. Unscrew the whole assembly from the carb and clean it, check it for function and free it up.
