Fuel Pump or the injectors 2011 KX450F
I have a 2011 KX450F I purchased it about 2 months ago from a dealer that said that the bike had been totally gone through. I was at the track and all was fine then it quit. It acted like it was out of gas. I have talked to the shop and a few people about this.. I'm thinking fuel pump or injectors. Where should I start and where is a good place to buy good aftermarket parts.
Pull the pump
Remove the filter and replace it
Test the pump on the bench using hot water
Use a pressure meter if you like
The pumps when bad take several minutes to loose pressure or when get hot
