PWK 39.5 jetting help. 93 KX250
I just installed a Keihin 39.5 PWK carb off a 91 KX500 on my 93 KX250
Looking for jetting advice.
68.50mm bore 265cc ported, stock pipe and silencer.
You have a larger bore, which normally requires slightly leaner jetting. But the increased Bernoulli effect that a larger bore will cause if the carb stays the same size is likely cancelled out by the larger carb. So I would probably start with the stock jet sizes for your KX250 and work from there. I'll bet it's not really that far off.
Well I just had it out today 54 degrees and 43% humidity.
It started with a N82M needle on the second from leanest groove, #60 pilot and 170 main, air screw 1.5 out.
First run mas extremely rich.
Second I put needle on the leanest groove and installed a #48 pilot ( it's all I had ) still 170 main.
Ran better but still fat.
Today I tried a 165 main witch helped a little and now a 160 main.
It runs ok but still fat in midrange, sorta almost struggles to come on pipe, maybe a leaner main would fix it?
But I would like advice on a leaner needle cause it's on its leanest setting.
This is it's current setting, N82M needle on leanest groove, #48 pilot, 1.25 air screw, 160 main.
I might try a 150-155 main.
