2006 cr85 rear shock rebuild?
My brother has a 2006 cr85 he said his shock was a bit loose so I went to tighten it a couple clicks but it went as tight as it can go. It is still really soft I can almost push it to the bottom by hand. It has never been rebuilt or anything. Are the shocks just really loose or does it need a rebuild?
So if I adjust the rebound it might tighten it up? And I'm not sure what the spring rate is.
yes but it's not going to help if your spring is too soft or no pre load
Sounds also like it's due for a rebuild
