PLEASE help carb issue need help
Hello thumpertalk, yesterday I started a thread about my 1987 suzuki dr125 I had a problem with gas leaking out the overflow tube, someone said to clean the carb. I tried this and it stopped the leaking but started another problem. The bike won't run without the choke and with the choke on it will idle very high, I tried turning down the idle screw and almost unscrewed it, nothing helped. So I turned the bike off. Please help me I would greatly appreciate it.
-dirtbikepolo aka josh
Remove the pilot jet
Notice the size
Throw it away
Buy a new one
Clear the passage above the pilot jet with fishing line and spray cleaner
Install new jet
Open gas tank
Point a flashlight inside
Look for debris
If there is any, put  in a line fuel filter
Treat your gas with PRI-G or Stabil for Ethanol
