Electrical Problems with drz400s. Please help.
So I guess I should've seen something going wrong with having my bike sit outside for the last couple months. Anyways, I need to know if I should worry. The blinker indicator light (not the blinker) is staying on intermittently. When I first turn my bike on it doesn't turn on, but then after a couple minutes of riding the light starts flickering. The more power I give, the stronger and more steady the light. My blinkers still work, and the light still flashes when my blinkers are on. After about 15 minutes the light stays on, not at strong as when a blinker is on though. Should I be concerned about this? I don't like that it stays on, but isnt affecting the blinkers or anything. I'll get a video when it stops raining.
Sounds like a bad ground or a short. Check the wires from the signal back to the connectors. See if any wires are bare and touching the frame or each other
