Eibach Springs
I've been severely disappointed with my 98 XR4 front suspension at the track so I decided to perform the shim stack mod.  After pulling the compression bolt, I count only 7 shims (stock shim count for 96 & 97) rather than the stock 12 shim count that a 98 is supposed to have.  So this tells me that someone has replaced the front forks.  Ok, so I pull the spring and see that it has an aftermarket Eibach spring that is stamped with 21/93  996.024.0.  I cannot find this spring anywhere on the internet but it really sounds like a 24 KG/MM spring rate.  I really hope not because I am 180 lbs and that is a much lower spring rate than stock on a bike that is already undersprung.
So can anyone tell me what the specs of his spring is and what the 21/93 means?
I think just below that number on the spring are the numbers you need. I will take a look at a set later and update if not correct info.
