84 XL350R Crankshaft Bearings
Does anyone know or have the dimensions of the 84 HONDA XL350R Crankshaft Bearings ? I want to order Bearings direct from a Bearing Distributor prior to disassembly. O.D. X I.D. X Width.
And another thing Thanks for the addition to TT. Looking forward to corresponding with you.
The Honda part fiche will list the the standard metric bearing info if it is a standard metric bearing, but most crank bearings are non standard so your best bet is to buy them from Honda. Crank bearings also have special clearance requirements because of the thermal gradients encountered and the variety of fitting clearances.
